Fuel Pump help
Old Mar 13, 2011 | 02:17 PM
amanda waddell's Avatar
amanda waddell
Fuel Pump help
i have a 2000 e350 econoline and it is getting no power to the fuel pump.... have changed all the sensors also relay switched checked the fuses and still nothing wont turn over... does anybody know anything to help me out?
Old Mar 13, 2011 | 04:10 PM
havi's Avatar
havi
I'll have the Roast Duck
There's a ground wire that goes directly to the battery that supplies current to the fuel pump... it's a smaller wire than the big black cable. At least that is one issue on an '85 F150 EFI I have. A couple others are the fuel pump relay, and the inertia switch. Might have better luck asking here, too:
https://www.ford-trucks.com/forums/forum128/
Old Mar 15, 2011 | 07:54 PM
JWA's Avatar
JWA
Does it turn over but not fire?
Do you for certain there is power to the fuel pump itself? Certainly the ground wire could be an issue but from experience with an '88 E150 the connector essentially fell apart about 130 miles from home---it was a memorable experience not in a good way though.
loggerlife15
Jan 12, 2016 09:57 AM
skalrim1134
1978 - 1996 Big Bronco
Dec 24, 2010 02:30 AM
mikesmayhem
Modular V10 (6.8l)
May 11, 2009 11:40 PM
csuteau
Aug 19, 2008 04:24 PM
jtttj
Jul 5, 2008 09:03 PM
