1978 - 1996 Big Bronco
5.8 intake plenum
Old Mar 16, 2011 | 08:51 PM
Capone's Avatar
Capone
If your truck is speed density then stick to a camshaft that is
numerically equal to or less than 215 degrees of duration (265 advertised).
Keep lift at a conservative .460in to keep piston to valve clearance a non-issue. Keep LSA above 112 as speed density
goes nuts with anything with too much duration and too little LSA.
I would suggest 210/215 .460/.460 @112
I think this is one of the largest cams you can run without issues.
Cardinal
Oct 27, 2024 11:23 PM
ExPACamper
28
May 12, 2017 11:31 AM
MonroeHandyMan
33
Nov 13, 2014 06:42 AM
Steve in NC
Jul 30, 2014 05:29 AM
Wilber15
May 20, 2002 05:54 AM
