water pump
Old Mar 13, 2011 | 10:19 AM
lunchboxchoch's Avatar
lunchboxchoch
water pump
i need help i recently bought a ford 97 f-250 diesel it now needs a water pump .I'm a newbie when it comes to fixing diesels .can anyone give some step by steps to make this not so much a mf. thanks
Old Mar 13, 2011 | 10:49 AM
Copedawg's Avatar
Copedawg
WELCOME TO FTE!!!
Here are some links you should save:
1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
http://pages.prodigy.net/stevebaz/_i...az/index3.html
1996 Bronco/F-Series Workshop Manual
97-15A 7.3L DI Turbo Workshop Manual
I have not changed the water pump on mine....yet (knock on wood) but I believe it is fairly straight forward. I am sure someone has a write up for you to follow.
Where are you located? how many miles do you have? 4X4? Auto?
Stick around and ask as many questions as you can. This is like a 24/7 technical help site and the price is right!
See you around!
Old Mar 13, 2011 | 12:22 PM
lunchboxchoch
water pump
Its a 4x4 manual with 145k on her
Old Mar 13, 2011 | 01:34 PM
DRRXR's Avatar
DRRXR
Drop underneath and remove the small hoses from the plastic fan shroud on each side. Then using a long chisel rap tap the fan clutch nut on the right side twice. Then try and unscrew it. Pull fan and the shroud out at the same time. But you may want to put something in there to protect your radiator from the fan if you are pulling it by your lonesome. Make sure that the old gasket material is cleaned from the mating surface really well before the install and you may want to change the thermostate out to from a 195 to a 203 just make sure that the lenghts are the same.
Old Mar 13, 2011 | 02:18 PM
FARM69's Avatar
FARM69
Good visual explanation here... Cover the radiater with cardboard before you remove the fan.
YouTube - Water Pump RnR
