Modular V10 (6.8l)
HELP-Differential
Old Mar 12, 2011 | 04:17 PM
klr650goldwing's Avatar
klr650goldwing
HELP-Differential
I just crawled under my F350 V10 4X4 to change the differential fluids and noticed there isn't a fill plug in the differential cover. So where is it? Or, do I need to buy an after market cover in order to change the differential fluid and re-fill it with new fluid.
HELP!!
Old Mar 12, 2011 | 06:54 PM
onug's Avatar
onug
Ford doesn't put a drain plug in their diffs. You have to put the cover off and either reseal it or install an aftermarket.
The lack of a plug drives me nuts, so I'm going to install aftermarket ones when the time comes.
Old Mar 12, 2011 | 07:46 PM
spinella's Avatar
spinella
the fill plug is near the rear u-joint on the drivers side,use a 3/8 rachet to remove it. the front diff cover has the fill plug in the cover.
Old Mar 13, 2011 | 06:01 PM
klr650goldwing
Thanks Guys,
I found it. Older differentials used to have the filler plug on the back. Not so with this one.
Old Mar 14, 2011 | 08:17 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I use a hand vacuum pump with a fluid catcher on it to suck out the fluid through the full plug. Just be careful not to lose the hose
