Rust all on the underside?
Old Mar 15, 2003 | 02:11 PM
mike_mck2's Avatar
mike_mck2
I'm not sure if this is normal or not.
I was underneath my Ranger, changing the oil and looking at the fuel filter, and I noticed that there is alot of rust everywhere. Not big flaky rust really, it's more finely grained, but it's pretty extensive.
Is this normal?
I'm in Texas, BTW.
Old Mar 15, 2003 | 07:09 PM
mrwizard's Avatar
mrwizard
What year is your Ranger? Have you had it since new? If not, could it have been somewhere that uses salt on the roads in the winter? Salt = rust.
Old Mar 16, 2003 | 11:11 AM
mike_mck2's Avatar
mike_mck2
It's a '99 that I bought from a local dealer.
I was thinking maybe it had been brought down from somewhere that used salt on the roads, but I checked another Ranger, a '98, and it looks pretty much the same as mine.
The owner of the '98 bought it brand new here in Texas, so I'm thinking it's normal after all.
It's not a major amount of rust really, but it did get me to thinking.
Old Mar 16, 2003 | 07:37 PM
saintthomas's Avatar
saintthomas
I have a 98 ranger myself. Mine has under body paint. There is NO rust on the painted surfaces. All the unpainted surface have surface rust. I plan to paint the entire bottom after a little scoth-brite. I would expect the rust is normal since ford hardly uses SS or aluminum, except on the fuel lines. Don't worry about it unless it is just an issue of looks. If it makes your eyes twitch headed to the store for some primer grey. Alot of people use black. FYI grey is much easier to spot leaks.
Old Mar 17, 2003 | 08:59 PM
1991rangerford's Avatar
1991rangerford
heck better than my 1991 my doors are completely shot and the driver side cab corner.
....anyways...i'd say if it bugs ya get under there with some sand paper,
Grab some RED OXIDE PRIMER in spray cans. Get good stuff..like
Krylon Rust Tough...i swear by that stuff!
i know my cost at work is 2.50 a can...walmart probably is cheaper tho ) they by 500,000 dollars worth of pait, we buy 2,000 )
