P0401 Code on a Ford V-10
Is this common on these vehicles? Should I find a vacuum source, and run a can of Sea Foam in it?
This vehicle normally does not get used much, but these past few weeks, I've been driving it almost every day.
Any help would be appreciated.
John
Last edited by 98ClubWagon; Mar 12, 2011 at 08:35 AM. Reason: Put down wrong code number: should be P0401
So, since I can't change the title (I don't know how), the code should be: P0401.
Sorry,
John
P0401: EGR low flow-Check vacuum supply and valve operation .
Here are few things to check ( from haynes book ) ;
1-Make sure vacuum hoses are in good condition and hooked up correctly.
2-To perform a leakage test ,attach a vacuum pump to EGR valve . Apply a vacuum of 5 to 6 in-Hg to the valve .The EGR valve should hold the vacuum .
3-Remove the EGR valve and clean the inlet and outlet ports with a wire brush . Donot sandblast the valve or clean it with gasoline or solvents .These liquids will destroy the EGR valve diaphragm.
Good luck,
Good luck,
With all my crying out of the way, where exactly is the EGR? Do you know which side? I'm hoping once the dog house is off, I can get to it somewhat easily.
Thanks,
John
There should be a metal pipe coming out of exhaust manifold into the intake manifold ( most likely at driver's side) . EGR valve is on the intake manifold side of the EGR pipe. My guide book gives this procedure :
1-Remove the air cleaner outlet tube.
2-Remove the vacuum line from the EGR valve (if equipped).
3-Remove the bolts and position the differential pressure feedback EGR bracket out of the way
4-Disconnect the EGR tube fittings and position the EGR tube out of the way.
5-Remove the two bolts and the EGR valve.
Another piece of info
From Haynes ) The EGR flow rate is determined by monitoring the pressure across a fixed metering orifice as exhaust gases pass thru it .The system is called DPFE (Differential Pressure Feedback ). The DPFE pressure sensor monitors upstream and downstream exhaust backpressures. This backpressure coefficient is relayed to the PCM and the correct amount of EGR duty cycle is applied to the EGR vacuum regulator control (EVR )....................
Sounds like DPFE sensor and/or EVR vacuum regulator valve could be the culprit too .
Take your time and find out how you can test these .
Good luck .
That description you gave from Haynes, is that for the van? Or Pick up? Just wondering if it's accessible from the front, or from the rear? The description says take off the air cleaner outlet tube, so if that is for the van, then I can assume that it can be accessed from the front?
Thanks,
John
I suspect it's really the DPFE sensor, which is usually the reason for this.
I do have an AutoXRay 6000 scan tool, that also does live data streaming. Does anyone know what I should be looking for, in the data streaming, to determine if it's actually the EGR, or the DPFE sensor? Is there a way to find out using the scan tool? I would rather try something like that, as opposed to taking the thing apart, and checking the EGR with vacuum, like you guys are saying. If this was a pickup, or car, then I'd jump right in. But, being a van, you guys know how much of a pain it is to work on these! I'm sure that the EGR is probably in the back, where I'd have to take off the 'dog house' in the van.
Thanks,
John
Of course, you COULD watch the EGR duty-cycle, versus the DPFE flow rate, and as the EGR duty cycle increases, the DPFE flow rate would increase as well. If there is no change as the EGR duty-cycle increases, that indicates the EGR is not opening, OR the DPFE is bad.
So, even with datalogging, you're still stuck with "what's causing the issue" and you'd STILL have to manually test the EGR to see if it's working
The EGR will come on as you slowly tip into the go-pedal. I used to watch the EGR on my '96 t-bird with an Autotap, and found it was coming in WAY too early and causing a stumble right off-idle. Putting a small restrictor in the vacuum line kept it from coming on too fast, didn't trigger the PCM/DPFE, and got rid of the stumble. But I never did find a PID for the DPFE flow. Maybe I didn't look well enough ...
This might help you;
EGR Valve Position Sensor
The EGR valve position sensor is a potentiometer that monitors the movement of the EGR valve pintle. The EGR valve position sensor then provides the pintle position to the PCM. The EGR valve position sensor signal varies from approximately 0.50V when the valve is closed to approximately 4.5V when the valve is open.
Good luck
Ken
Thanks for clarifying this. I will hook up the scanner, and monitor it. But, when I have time, I will also take off the dog house, and check the EGR.
Like I said before, if I try to go too soon after starting the engine, then the check engine light comes on. But, if I let it warm up a bit, then it seems OK.
I'm just wondering if it's not build up, and I put a can of sea foam through it, if it would clean it up? Some people swear by putting it into a vacuum source, and letting it run. It smokes like hell, but people swear by it. Have you ever tried it? If so, does it work?
John
John
