stripped lug nut
Old Mar 11, 2011 | 05:30 PM
aking225's Avatar
aking225
stripped lug nut
alright guys, i have an extremley stripped lug nut on my rear tire, i need to get it off to do the ebrake, any ideas, me and my dad are stmped
Old Mar 11, 2011 | 06:08 PM
L. Ward's Avatar
L. Ward
Careful work with an oxy/acetylene
Old Mar 11, 2011 | 06:33 PM
rla2005's Avatar
rla2005
Ouch....that will work but be prepared to replace the stud. No big deal really, but it probably is your best choice outside of a cutoff wheel.
Old Mar 11, 2011 | 06:36 PM
CJM8515's Avatar
CJM8515
Few choices:
1. If your careful with a grinder and cutting wheel you can cut it off
2. Cut the stud off and just replace it
3. Torch the nut/stud off
4. Go to any parts store and find a 12 point socket that fits it well over the nut. Pound it on if you have to then take a breaker bar or a big ratchet and get it off. If your lucky and can find a bumper with a hole for a hitch ball in it, take the socket, a decent punch and a small sledge and you can pop the busted nut out. Then take the socket back or keep it.
5. Sears and similar makes bolt offs which will remove damaged nuts
6. Nut splitter from sears.
zxwut?'s Avatar
zxwut?
weld another nut to it
Old Mar 13, 2011 | 10:46 PM
aking225's Avatar
aking225
Thanks for the replys guys how hard is it to replace a stud?
Old Mar 13, 2011 | 10:50 PM
fdude64's Avatar
fdude64
just knock it out and put a new one in
Old Mar 14, 2011 | 12:03 AM
rla2005's Avatar
rla2005
Sort of that easy....Remove the hub/rotor then R&R the stud.
Old Mar 14, 2011 | 12:38 PM
RustyGreen's Avatar
RustyGreen
ooooh, I like that idea!!!! I'm gonna remember that one Thanks!!
Old Mar 14, 2011 | 12:54 PM
91chevywt's Avatar
91chevywt
If you put a 4 way lug wrench on it, and pull up or down on the bar at the very end, you might be able to snap it off. I did this on a car by-accident once when I wasn't paying attention to what I was doing. Not sure if it would work on a 1/2" stud though. Then replace the broken stud. They do make sockets for stripped nuts, which have gotten me out of a jam a couple times.
Old Mar 14, 2011 | 02:45 PM
F-series Fan's Avatar
F-series Fan
If you heat the stud or around the stud DON'T forget to let air out of the tire, or you could get a big BOOM, But like mentioned before weld another nut to it, then remove, either way replace the stud, any heat will weaken it.
Old Mar 14, 2011 | 04:04 PM
zxwut?'s Avatar
zxwut?
How is the tire going to explode by tack welding on a nut to the stud??...
Old Mar 14, 2011 | 04:16 PM
CJM8515's Avatar
CJM8515
maybe someone welded so much on the stud/busted nut they heated the rim up?
Old Mar 14, 2011 | 04:25 PM
White 97 xlt's Avatar
White 97 xlt
If that's true, welding school is in order!!!!
Old Mar 14, 2011 | 04:48 PM
zxwut?'s Avatar
zxwut?
That sounds extremely far fetched. You'd burn through the rim before it produced enough heat to change the temperature in the tire.
