Mechanical Gauge Installation
Old Mar 11, 2011 | 01:46 PM
mr_ranger-79's Avatar
mr_ranger-79
Hello all. I am installing a mechanical gauge set on my 1979 F-250 Ranger 4x4. I hooked up the water temp gauge to the thermo housing, but got to wondering if I should instead put it in the same location as the original temp sending unit? Also, does anyone know where the oil pressure sending unit is? I cant seem to find it. This is the 400 c.i. engine. Thanks.
Old Mar 11, 2011 | 03:19 PM
smokercummins74's Avatar
smokercummins74
7th Gear
The oil pressure sending unit is on the top rear of the engine next to the vacuum tree. Also in regard to the water temp gauge I have mine in the thermostat housing as well and while probably not ideal it still gives you a pretty good reading of the coolant temp, after the thermostat opens anyway.
Old Mar 11, 2011 | 03:40 PM
mr_ranger-79
Thanks...thats why I wondered about water temp location. It obviously wont do anything until the thermo opens...but no biggie I guess.
