EGR valve
Old Mar 10, 2011 | 08:00 PM
D Ray's Avatar
D Ray
EGR valve
I am planning to remove the EGR valve and clean the ports. I have the "insufficient EGR flow" CEL code and figure that after 185k on the 97 expy (4.6) it's time to clean it. The vacuum is good so I am sure it just clogged ports. The problem is I can't get the EGR tube out of the back of the valve. The EGR tube was replaced a few years back after rusting out at the exhaust manifold but it still has the factory valve. PB Blaster hasn't loosened it up any and I'm worried about rounding off the head on the EGR tube- which is still in good shape.
Any tips or tricks for getting that thing out? There isn't much room back there so I was wondering if it would be easier to take off the EGR valve to get enough flex from the tube to get a better grip and angle on the nut going into the valve.? Any advice is greatly appreciated.
Old Mar 11, 2011 | 08:54 AM
alloro's Avatar
alloro
If you can get the EGR valve off, then maybe you can clean the ports without disconnecting the EGR tube. If you're determined to get the tube off I would be sure to use a flare nut wrench instead of an opened end one. Get the flare wrench on it and shock it with a good hard smack from a 3 lb. sledgehammer. With the flare wrench you'll be grabbing 6 corners of the nut instead of just 2. But don't use a cheap one because it will spread and round the corners, instead go to Sears for one. Heating the nut up with a propane torch can help too.
Old Mar 16, 2011 | 05:36 PM
D Ray's Avatar
D Ray
Thanks alloro and armandjones82. By chance do you know what size the EGR nut is?
Between the weather and work I haven't had the chance to mess with it - but will let you know how it goes after I either fix it or fubar it!
Old Mar 16, 2011 | 06:28 PM
alloro's Avatar
alloro
I want to say 22mm, 7/8" or 1" but I can't be sure. It's been 2-1/2 years since I un-did mine.
cberr
1997 - 2003 F150
21
Feb 22, 2016 07:02 PM
Thorntontribe
Nov 23, 2014 03:30 AM
JoePeeper
Jul 11, 2013 12:58 PM
96_4wdr
Aerostar
Feb 22, 2013 11:07 AM
maniac2025
1997 - 2003 F150
Aug 15, 2011 08:06 PM
