6.0 / V10 Trans cooler
Alright, went out, looking under my truck, 6sp, to find the culprit with the swaybar bushings and linkage arms, while i was under there, i notice that my trans cooler lines go to the bottom of the radiator. I started looking around, and nowhere do i see the stock trans cooler? Does the 6sp (L99) come with them or dont they, and if not, think it would be a good time to thru SOMETHING under it, right...again, thank you much.
I didn't know the 6spd had a cooler at all. Do you have a temp gauge on it. And do you tow heavy. I don't see know need if your not towing heavy and temps aren't up. Thanks for the input, I like to see who else chimes in and there set up. Maybe Dan mit chime in. He's got a 550 and tows heavy with his 5ther.
alright...just was shocked when i didnt see anything, considering i see the 6.0 or stock ones in alot of threads. So if i wanted to install one, i guess just put a fitting off the return from the radiator, then take a line to the external one, then from there, back to the hardline for the return...? Just not sure if i want to mount it in front of the condensor or under the IC.
