Latest Flash
Old Mar 10, 2011 | 10:49 AM
rocky1074's Avatar
rocky1074
Latest Flash
I would like to know when the Latest Flash came out; Strategy and if there's a TBS on it..Thanks
Old Mar 10, 2011 | 10:58 AM
Zmann's Avatar
Zmann
I know it was about a year ago .. it was a month after I had mine done lol
why are you asking ? to see if you have it ???
EDIT looks like the VXCF9 was nov 2009 ish
Old Mar 10, 2011 | 11:17 AM
rocky1074's Avatar
rocky1074
No my son just purchased a 06 in Florida and brought it back home in PA. He's having some cold start issues. New FICM was installed don't know when. I was just wondering if he has the latest flash. I have read from other posts that it helped with cold start issues.
Old Mar 10, 2011 | 12:43 PM
Zmann's Avatar
Zmann
the one before that helped also .. find out what he has if it is older than the last 2 I would update otherwise I would leave it ,, post up the # if u get it pulled from the PCM
what issues ,,??
Old Mar 10, 2011 | 05:08 PM
rocky1074's Avatar
rocky1074
From what I'm told when cold it runs very rough like an 8 cyl gasser running on 6 other than that when warm runs great!!
Old Mar 10, 2011 | 05:11 PM
npccpartsman's Avatar
npccpartsman
VXCF9 is the latest for 05-07. If it doesn't have that flash then I'd get it just to "redo" the aggressive FICM strategies of the earlier flashes. The flash came out in Dec. 09.
Old Mar 10, 2011 | 05:12 PM
BRay09's Avatar
BRay09
I also have an 06 and was wondering if i should go get the "latest" flash on my truck. how do i tell which one i have and if i should/shouldn't get the new flash
Old Mar 10, 2011 | 05:59 PM
rocky1074's Avatar
rocky1074
Thanks Bill, I posted your reply on Super Duty & Heavy Duty Page where my son roc2178 posted (Florida 6.0 not liking the Northeast) He purchased an 06 F-250 4X4 short bed down here in fl and we both drove it back to PA and it ran great. After the purchase while here I changed oil & filter with Rotella 5X40 synthetic & Racor filter; Replaced Fuel Filters with Racor Brand..Dropped trans fluid and replaced about 7-8 qts and installed new ntz filter..Told him to drop trans fluid a least 2 more times..Installed Fumoto oil valve..Installed updated HFCM water drain plug; Installed engine block heater cord. I think that would have gotten him started. Wanted to do a complete VC-9 and coolant flush but we didn't have time as he had to get back up north. Truck is running great except for the cold start!!! Thanks Rocky
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
Old Mar 10, 2011 | 06:06 PM
smokersteve's Avatar
smokersteve
Tuning is not the issue with the cold starts. It is a build up in the injectors with the oil. I feel that programming only covers the issue up and does not "fix" it.
What oil is he using? how often is he changing it? what filter?
Old Mar 10, 2011 | 10:16 PM
rocky1074's Avatar
rocky1074
I used Rotella 5X40 synthetic & Racor filter was just changed when truck was purchased 2 weeks ago. I think he should try Rev-X other members on FTE seem to have good results with it.
Old Mar 10, 2011 | 11:26 PM
4X4X4RV's Avatar
4X4X4RV
I agree try the Rev X a little pricy but I found it solved my rough start problems.
Old Mar 11, 2011 | 09:04 AM
rocky1074's Avatar
rocky1074
I myself have 2 bottles of Rev-X sitting on my shelf for future use, I know I will need it sooner or later, so like to have it on hand..Yes pricey it is!!!I think I paid 72.95 total with shipping from rev-x website.
