Alternator ?
Old Mar 9, 2011 | 10:57 PM
79FORD-DENT's Avatar
79FORD-DENT
Alternator ?
I just did a 3g alternator upgrade but my headlights still dim brighter n lowre as my rpms go up n down....now even my radio illumination dims high and low depending on my rpms...
Old Mar 9, 2011 | 11:03 PM
co425's Avatar
co425
It's your headlight switch you need to relay your headlights.
Old Mar 9, 2011 | 11:09 PM
79FORD-DENT
Oh ok...what I meant was dat my headlights get brighter when I step on the gas pedal..but my alternator its puttin 14.9 v ...thats why I dont get why my lights stll get brighter when at a higher rpm stance
Old Mar 9, 2011 | 11:27 PM
co425's Avatar
co425
Sounds like you might need to go through and clean, replace or add some ground straps. I have 5. Bed to frame, cab to frame, battery to engine block, frame, and radiator support. All are made from 4 ga battery cable with soldered lugs.
Old Mar 10, 2011 | 12:02 AM
Hawk 1's Avatar
Hawk 1
What he said
Old Mar 10, 2011 | 03:04 AM
78 PEB's Avatar
78 PEB
X 3...........before I added my ground straps on my 78 F150 my lights would get brighter when I'd step on the clutch.............my first clue I needed them...........also had a 77 F150 years ago that after rebuilding the engine, the alternator wouldnt charge at all..........added ground straps and again problem solved.........
Old Mar 10, 2011 | 12:02 PM
79FORD-DENT
This started happening when I did my 3g upgrade because when I had my stock 60 amp alternator this would not happen and I had more electronic stuff running of it...
