No starter
Old Mar 9, 2011 | 03:43 PM
ronjon95's Avatar
ronjon95
Exclamation No starter
Buddy of mine is sitting at home trying to start his truck. Early 99. The starter silnoid just clicks once and no rotation. Changed the Noid no difference. Charging the batteries also. just got home about an hour ago and truck wont start. HELP needs truck now! Alternator has humming noise while key is off.
Old Mar 9, 2011 | 03:45 PM
Skip1970's Avatar
Skip1970
bad alternator? i would disconeect them batts to save um, and put them on the charger, and disconnect alt and try starting again.
Old Mar 9, 2011 | 03:47 PM
Brother Les's Avatar
Brother Les
Did he have the starter off the truck and tested to make sure it is in working order. Also, the starter bolts sometimes back out (one of mine fell out) and you may not be getting a good ground.
Old Mar 9, 2011 | 03:51 PM
ronjon95's Avatar
ronjon95
New start last year new alt this Fall and batteries. Starter is not turning at all.
Old Mar 9, 2011 | 04:05 PM
Brother Les
You say that you changed the silinode on the starter. To do this you had to take the starter off of the truck. I assume that it tested fine after this fix? Was the silinode installed correctly? when putting the starter back on did you bolt it tight for a good ground? Did you get the hot wire and starter wire on correctly. Did you NOT break the starter post by turning it too far after it was snug (I broke mine off once). The starter may be on a 'dead' spot. Whack it with a hammer a couple of times and then try to turn it over.
I don't think that the Alt should be humming with the key off.
Old Mar 9, 2011 | 04:42 PM
ronjon95's Avatar
ronjon95
Bump it up!
Old Mar 9, 2011 | 05:18 PM
bcaughhorn's Avatar
bcaughhorn
bad starter. i just went through the same thing.
