Please help
Old Mar 8, 2011 | 07:41 PM
White350's Avatar
White350
Please help
I am new to this site and need help. i had just bought a 2002 f350 powerstroke about 3 weeks ago its my first deisle and i was driving up the road and all of a sudden my truck shut off and when i got out there was about 5 quarts of oil on the ground it is coming from the front of the engine looks like behind the balancer to my knollage the truck shut off because of the low oil i guess its a safety thing i was just wonderig if it could be the crank seal and how hard they are to change thanks
Old Mar 8, 2011 | 07:53 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Powerstroke Diesel forum.
Old Mar 8, 2011 | 07:58 PM
timmyboy76's Avatar
timmyboy76
taking a stab at it, but if thats the case, it sounds like the lpop (low pressure oil pump) let loose, and believe theres a seal behind it
Old Mar 8, 2011 | 08:13 PM
F350-6's Avatar
F350-6
Welcome to FTE. Crawl up on top of the motor with a flashlight. Is there a bunch of oil pooling on top of the motor?
Your fuel injectors run off engine oil so that's why the truck shut down. Usually a big leak like this is the result of a blown o-ring or oil line. Something you'll be able to fix yourself once we find out for sure where the oil is coming from.
Old Mar 9, 2011 | 06:08 PM
White350's Avatar
White350
well its deffinetly coming outaa the font seal and i stoped at the parts store and they have no listing for a front crank seal could it also be called a timing cover seal they look kinda the same
Old Mar 9, 2011 | 06:17 PM
zx250's Avatar
zx250
Of the next Riffraff East
While front seals do fail, it's not common at all. Make sure it's not higher up on the engine. Lots of places for these things to leak other than a seal.
Old Mar 9, 2011 | 06:33 PM
White350's Avatar
White350
can you tell me were cause it gushing out from behind the balancer
Old Mar 9, 2011 | 06:45 PM
zx250's Avatar
zx250
Make sure your CPS is still in it's hole. Make sure it's not coming for above and running down past the balancer. The High Pressure Oil Pump (HPOP) sits on the top, front of the engine and anything around that can leak. It can even spray oil to a different location. Just don't seen to me that a front main would fail that bad, that fast. Now a HPOP will pump out 5 qts of in a very short time
Old Mar 9, 2011 | 07:15 PM
White350's Avatar
White350
i noticed a leak about a week ago up front of the engine on the staering lincage i have a 6 step programmer on it and had it turned up all the way and i jumped on it yesterday and thats when something gave loose oil leak wise
Old Mar 9, 2011 | 07:17 PM
zx250's Avatar
zx250
You blew a high pressure oil line somewhere, it will be near the front. You may have even cracked your HPOP. Look for signs of oil under and around it.
Old Mar 9, 2011 | 07:22 PM
BigAlsPSD's Avatar
BigAlsPSD
Only thing else I can think of is the oil cooler? The front mounts justs above the pitman arm? So thats a possibility.
Old Mar 9, 2011 | 07:47 PM
White350's Avatar
White350
is there any high pressure lines on the front of the engine cause its dry from the water pump up just a little damp from it hitting the belt and splashing up
Old Mar 9, 2011 | 07:49 PM
White350's Avatar
White350
like i said im new to the deisle world if this was a 460 or bigger i would be golden is the hpop in front of the fuel filter
Old Mar 9, 2011 | 07:51 PM
BigAlsPSD's Avatar
BigAlsPSD
Yes its resevoir is easily visible and sits on top of it, underneath the "Powerstroke" cover.
Kwikkordead's Avatar
Kwikkordead
Subscribing here.
I have to agree with the other guys here, look between the cylinder heads for a big pool of oil down in the valley.
If it blew out the front seal like you are saying, then that's kind of a new problem that we don't see with the 7.3s.
