I had to remove my transmission to replace the rear main seal. When I put the trans back on I jammed the TC on the the trans and broke the gears for the pump. I took the trans in to the shop and had it repaired. Put the trans back in, without jamming the TC. I took the truck out for a spin and it's not shifting. Any ideas on what could be wrong? I've already adjusted the linkage and the fluid is good to go. Please help. This is my daily driver and I need it back.
The directions in the video are pretty good, but by disconnecting the cable from the ballstud you've got a better shot at finding the neutral position on the cable.
__________________
