Sponsored by: Auxito
headlights
Old Mar 14, 2003 | 08:10 PM
txdodg7680's Avatar
txdodg7680
headlights
I have a 2000 Ford Ranger. My high beams won't come on I have low beams but no high beams . Could anyone tell me what is wrong
Old Mar 14, 2003 | 11:04 PM
Racerguy's Avatar
Racerguy
headlights
Hi txdodg7680(No Email Addresses In Posts!) and welcome to FTE
Your problem is hopefully as simple as both bulbs are burned out or a burned out fuse for the high beams lights in the underhood fuse box. Check those things first. If both those check out ok it could be your multi-function switch (dimmer switch/wiper/signal switch).
Does the high beam indicator on the dash come on? If it does then the problem is probably the bulbs. If not, check the fuses first.
FYI there is a Ranger forum further down the main forum page with a bunch of really good people in it
