Engine Replacement Tips
I finally got a replacement 460 for my 250, and I have never had to replace a engine before. Is there anything that I should really worry about? The engine is currently set up as a generator, so there are a couple of things that I will need to remove, but should things like my ac pump ect. bolt on with no problems?
If it is your Ranger with the 460 already in it, like Jim said all bracks will intercahange. I would unbolt the A/C and hang it on the side without disconnecting the hoses. On a
2wd, I would pull engine with the trans, That way you can put the trans and engine togather easier and put it back in.
vrinner
01-23-2016 07:09 PM
cookingguy
08-19-2014 09:14 PM
BigNick98
06-03-2014 01:43 PM
