Engine Replacement Tips
Old Mar 7, 2011 | 06:08 PM
jgavac's Avatar
jgavac
I finally got a replacement 460 for my 250, and I have never had to replace a engine before. Is there anything that I should really worry about? The engine is currently set up as a generator, so there are a couple of things that I will need to remove, but should things like my ac pump ect. bolt on with no problems?
Old Mar 8, 2011 | 07:47 AM
jim collins's Avatar
jim collins
If you are replacing a 460 with another 460 then just transfer the brackets ect. over to the new engine. If it's something other than a 460, we need too know what it is. JIM
Old Mar 8, 2011 | 08:49 AM
bertha66's Avatar
bertha66
If it is your Ranger with the 460 already in it, like Jim said all bracks will intercahange. I would unbolt the A/C and hang it on the side without disconnecting the hoses. On a
2wd, I would pull engine with the trans, That way you can put the trans and engine togather easier and put it back in.
Old Mar 8, 2011 | 09:05 AM
704 dentside man's Avatar
704 dentside man
Don't forget the ground straps.
vrinner
Jan 23, 2016 07:09 PM
cookingguy
Aug 19, 2014 09:14 PM
BigNick98
Jun 3, 2014 01:43 PM
SoCalJim
1997 - 2003 F150
May 9, 2014 10:33 AM
kennethpina
Dec 16, 2010 01:19 PM
