No start problem..
Old Mar 7, 2011 | 08:24 PM
laworange78's Avatar
laworange78
No start problem..
<!-- / icon and title --><!-- message -->
I am needing some advice. My daily driver is not starting I replaced all the glow plugs, controller and batteries a few months back. I came out yesterday and it would just crank like it did with bad plugs. So I thought it was the cam sensor and that also didn't fix it. Is it possible that my plugs crapped out on me? I put Autolites in and found out later they aren't the best. Last week we 20 deg it started perfect now at 35 it does nothing. I haven't hooked my scanner to it yet. But I don't have a CEL on. Any help would be great. Thanks.
Old Mar 7, 2011 | 08:31 PM
onelionhunter's Avatar
onelionhunter
WTS
Do you get the wait to start light when you turn the key? If no wts, unplug fuel bowl heater and replace 30 amp fuse under dash, fuel bowl heater shorted. If you can read codes, thats even better thoiugh.
F350-6's Avatar
F350-6
Are you getting a bunch of white smoke while cranking? Does it start if you plug it in for a few hours first? Have you tried testing the GPR with a meter to see if you're getting voltage output?
Old Mar 7, 2011 | 08:39 PM
laworange78
I do get the WTS light and I just replaced the Relay a few months ago and I do get some white smoke I will test the relay too
Old Mar 8, 2011 | 06:01 PM
laworange78
I finally got time to do checking on why its not starting. My new GPR went out on me. No power on the second post.
Old Mar 8, 2011 | 06:08 PM
cgl's Avatar
cgl
So it is starting now? If so, thanks for the update!!
Old Mar 9, 2011 | 02:39 PM
laworange78
Not started yet.. I am waiting on parts delivery..
