5 speed to e40d change
Old Mar 14, 2003 | 03:16 PM
wyndancer's Avatar
wyndancer
I have a 93' f150 5 liter 2wd 5 speed. I want to change it to a e4od. I have most of the major items dealt with but I need to know what to do about the computer. also do I need to worry abut the shifter, I plan to go to an aftermarket floor shifter rather than change the column. any one got a parts list of what i will need?
Old Mar 14, 2003 | 06:17 PM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
an aftermarket shifter probley will not work with this trans, you will need a new computer and wireing harness to use this trans also.
good luck
Old Mar 16, 2003 | 02:57 PM
wyndancer's Avatar
wyndancer
is that because the computer needs a shift selector sensor to know what gear it is in?
Old Mar 16, 2003 | 06:59 PM
Diesel_Dummy _
the computer controls the trans .
Old Mar 17, 2003 | 11:49 AM
wyndancer's Avatar
wyndancer
I have discovered Bauman eng which makes a box that allows an e4od to connect to any ford engine without changing the computer. Do you know them and any comments on this solution?
Old Mar 27, 2003 | 04:55 PM
superhooperduty's Avatar
superhooperduty
I want to swap a 351 from a 82 -88 truck into my 91 now have a <a href="http://www.motorhaven.com/">302 </a>with the e40d, can i use the gizmo from Bauman so i can keep my e40d? the 351 will be non computerised, or should i change to a aod?
