Brakes failed
Old Mar 6, 2011 | 02:06 PM
mrstark44's Avatar
mrstark44
Brakes failed
So my red brake light and the yellow abs light came on. the truck is leaking what seems to be brake fluid from just in front of the rear driver side tires. I went under and there seems to be a slight tear/hole in the parking break line. other than that the lines seem to be wet but i don't know what im looking for.
the pedal is really soft, and i was barely able to get home. anyone know what this could be?
feel like i gotta replace the brake lines..any tutorials on this?
Old Mar 6, 2011 | 02:24 PM
84-250's Avatar
84-250
Its prob the rear brake line that goes from the RABS module to the rear axle rubber line. It is routed between the fuel tank and frame, that section rusts faster than the rest of the brake lines.
Old Mar 6, 2011 | 03:04 PM
97XLT4X4's Avatar
97XLT4X4
i agree, the best bet is to replace it from the master cylinder back to the rubber hose, it might help to replace the rubber as well.... isn't too labor intensive, just get a good quality flair nut wrench, the bleeders are 3/8 and make sure those open before beginning work or your in for a world of hurt.
i always go to napa for my brake lines and rubber hoses!
Old Mar 6, 2011 | 05:06 PM
bad12jr's Avatar
bad12jr
Feel it up with fluid and have someone pump it. you should see the leak. Also both lights will come on when the brake fluids low.
reelickj
Sep 21, 2012 01:11 AM
neilc88
Feb 13, 2012 08:37 AM
jrwhitey_2000
Nov 26, 2009 06:18 PM
netscaner
Jun 18, 2007 08:07 PM
Colo_Steve
Aug 30, 2004 05:00 PM
