Differences in the 7.3 engine
Old Mar 5, 2011 | 07:45 PM
F350-6's Avatar
F350-6
I thought this was interesting so I thought I'd share. http://www.fordtechservice.dealercon...es/52S01F0.pdf
It has several places in there that detail differences in these motors for different year models, and gives the serial number cut off for each one.
I also played around with the web address a little and came up with a directory listing here http://www.fordtechservice.dealercon...atabase/files/
My internet connection is too slow to open all the pdf's, so if you find other useful links, please post them here and I'll save a copy of those too.
Old Mar 5, 2011 | 08:48 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Thanks Chris.
Nice links. Saved for future reference. That's the first time I've seen the term "dusted" in a Ford tech manual.
Old Mar 5, 2011 | 09:01 PM
F350-6's Avatar
F350-6
What I thought was more interesting was they discussed dusting and said one of the common causes was a poor fitting air filter. We all know the factory air box is less than desirable. Looks like Ford might be kind of admitting similar info.
Old Mar 5, 2011 | 09:12 PM
onelionhunter's Avatar
onelionhunter
Great read
Chris,
Great read, I just skimmed through it, but saved it for when I have undistracted time to really read it. reps
Old Mar 5, 2011 | 09:13 PM
Shake-N-Bake
Yeah, I just saw that myself. Did you see the note on page 62 about which rod is likely to break if hydrolocked due to water ingestion? How does the CAC system make #4 more prone than any others? And why is #5 most vulnerable on non-CAC models? I can't figure that one out ...
More importantly, why would that comment even be in there? Almost as if to train the service techs with methods to claim it was owner neglect that caused certain engine failures.
Old Mar 5, 2011 | 09:27 PM
F350-6's Avatar
F350-6
I did see that part and thought it was interesting too. I wasn't as concerned as it being a way for techs to deny warranty coverage since that didn't really become too big of an issue until folks started chipping the 6.0. My only guess is it has to do with the way the spider directs air (or water) flow into the intake manifold compared to the non-cac engines.
If you stare at the spider and follow the air intake path through the intercooler, you can picture how water would flow over to the driver side bank coming out of the CAC pipe. On the older trucks, it would dump into the passenger side first since there was no momentum to carry it over to the driver side. Both cylinders they call out are near center, so I'm guessing that's the reasoning.
Old Mar 5, 2011 | 09:48 PM
gradyc's Avatar
gradyc
wellhead
Thanks Cris. Saved to favorites.
Old Mar 5, 2011 | 09:49 PM
Shake-N-Bake
Makes perfect sense. Thanks for the reply.
Old Mar 6, 2011 | 12:57 AM
SpringerPop's Avatar
SpringerPop
Makes me think that if I ever need a replacement engine to NOT pick up an early one and bolt on the late parts.
There's more to it.....
Pop
Old Mar 6, 2011 | 01:49 AM
SLUF681's Avatar
SLUF681
Good find. Reps sent.
Old Mar 6, 2011 | 09:40 AM
big poppa's Avatar
big poppa
Very interesting, nice find........
Old Mar 6, 2011 | 10:55 AM
Ponyboychris's Avatar
Ponyboychris
Thanks! Reps sent!
brickie
Jul 19, 2015 10:16 AM
bismic
Jan 31, 2015 06:41 AM
dualwheels66
Dec 30, 2014 08:22 PM
JWA
Sep 15, 2014 11:47 AM
beefcake
Dec 9, 2010 01:56 PM
