Spark plug diagnosis
Old Mar 5, 2011 | 06:37 PM
swammie's Avatar
swammie
Here are my sparkplugs. I just replaced with Autolite XP Extreme Performance Iridium. Any input from you guys/gals on the state of the old or the choice of the new?
The old plugs don't seem to point to a specific engine problem. In fact the old 1992 460 runs very well. I really can't say it runs "so much better" now that it's got the new plugs....I took it for a quick spin down the freeway and punched it a bit....don't really do that with it normally, so I can't compare. Now that I'm staring at the state of the old ones I'm embarrassed to say I'd put this job off, I let the skin on my knuckles talk me out of it before.
Old Mar 5, 2011 | 06:43 PM
zxwut?'s Avatar
zxwut?
The old ones look like butthole and very old. I would have went with copper Motorcrafts.
Old Mar 6, 2011 | 07:43 AM
EPNCSU2006's Avatar
EPNCSU2006
Other than being pretty worn, there is not anything unusual about the appearance of the old ones. Iridium plugs are pretty expensive and maybe overkill for a truck, but if it sparks reliably, you'll be just fine. They might last a bit longer than the standard plug, which could help with the knuckles .
Old Mar 6, 2011 | 12:57 PM
swammie's Avatar
swammie
The Iridium have a $2.00 each rebate through Nov 2011, so they were only about $3.00 each.
A record 2 scraped knuckles....love American trucks. Used anti-sieze on the threads to make it easier next time.
Old Mar 6, 2011 | 01:26 PM
planehunter's Avatar
planehunter
Looks like the bottom ones have an oil problem, probably a valve seal. You might also have some carbon buildup in the cylinders, try some seafoam and see if it helps.
Old Mar 7, 2011 | 04:01 AM
TexasGuy001's Avatar
TexasGuy001
I'll second the comment about Motorcraft coppers.
69f250Dually
Apr 13, 2013 10:06 PM
SideWinder4.9l
Mar 8, 2013 10:30 PM
TeamExploder
Projects
Oct 28, 2012 11:03 AM
SideWinder4.9l
1966 - 1977 Early Broncos
30
Mar 22, 2012 02:28 PM
Menghi08LT
Aug 21, 2011 07:30 AM
