C4 Spacer Plate on 56 f100
I am in the middle of a build and I would love some advice. I have a 74 C4 transmisson that I am fitting up with an 87 302. Once I got them fit together, I realized the spacer plate was offset where the starter is. Does any one know where I can pick up a spacer plate beside a junk yard? And one other (dumb) question, what is the main purpose of the spacer plate?
Thanks in advance!
Thanks in advance!
here are a couple of sources for block plates
with the c4 the size of the flex plate will determine which block plate you need. these two are multi-fit
Performance Automatic PA26445 - Performance Automatic Multi Fit Block Plates - Overview - SummitRacing.com[/URL]
Ford 289-351W C4-AOD Transmission Block Plate
Joe
Joe
If you can't find one used at the wrecking yard, you can get them new from Ford. Ford calls it a block plate. And it has to match your trans bellhousing and flywheel/flexplate tooth count. It serves several purposes, like indexing the starter, sealing the bellhousing area, creating the proper space between engine and trans, etc. Many automatics have a two piece block plate, with a removable lower section, like an inspection cover, to access the torque converter nuts.
hooler1
05-16-2014 11:47 AM
paige539
15
04-25-2014 11:59 PM
old ford user
04-05-2012 08:43 PM
