6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Help solve mystery ailment please...
Old Mar 4, 2011 | 07:20 AM
rdollie's Avatar
rdollie
My '08 PSD has started acting a bit odd in the past 2 weeks. It's louder to my ear (sounds closer to a 6.0 than a 6.4 all of a sudden), stinky often, and I get white(?) smoke under heavy acceleration. Also the fuel economy has fallen off about 25% based on the computer.
I have less than 16,000 miles on this thing even though it is my daily driver. Also, may or may not be relevant, ever since the updated reflash at the local dealer about 2 years ago I'm not sure this thing goes into regen anymore. I definitely haven't seen the message (which I understand is only around for a short period now) and only recall about 2 times when the motor ran at seemingly higher RPMs (and both time were while the truck was moving on the road and not at idle like my regens were before the reflash.)
Just to make things more interesting my warranty runs out in 3 weeks. Any insight into what should be checked/replaced would be appreciated. I'm going to schedule the truck for service next week - if my other vehicle is back from service by then...
Old Mar 4, 2011 | 12:03 PM
senix's Avatar
senix
Sounds to me like you have either and overfuel or maybe an EGR concern. I would take it in with all the issues you are having.
You will want to report the mileage drop along with the smoke and rougher running motor.
Old Mar 4, 2011 | 07:06 PM
kane gray's Avatar
kane gray
How is your coolant level? Do you regularly have to add any?
Old Mar 4, 2011 | 07:07 PM
kane gray's Avatar
kane gray
Also, check your oil and make sure it isn't heavily diluted and overfull from excessive regens, or leaking injectors.
Old Mar 7, 2011 | 08:06 AM
rdollie's Avatar
rdollie
Hmmm...interesting questions.
As it happens I added coolant just before this started to happen - not much about 12 ounces and as of yesterday the level hasn't changed.
What I did notice is that oil is way over the high mark on the dipstick. Also, as of yesterday, I'm getting 7 mpg per the computer...
Planning to drop this thing off unscheduled at the dealer later today before I fly out of town.
Old Mar 7, 2011 | 08:11 AM
senix's Avatar
senix
Be sure to point out really bad mpgs and high oil level...excessive regens?
