Euel line Help!!!!!!
Old Mar 3, 2011 | 09:03 PM
HD-runner's Avatar
HD-runner
Hi all. I have been hunting for some information. My F150 has reached its time for rebirth, new engine, paint and the price much less than a new tk.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I have also found that Ford no longer supplies some of the parts needed. I need some new o-rings for the fuel lines, supply line and return line where they attach to the fuel rail. Both lines do not look to be the same size. There are 2 o-rings on each line. Does anyone know what size the o-rings are or where I can get them from? The o-rings are not your normal o-rings but must resist the fuel and pressure like the VITON o-rings. <o></o>
Big Red XLT
Old Mar 3, 2011 | 09:29 PM
Encho's Avatar
Encho
The Southernmost Mod
Have you tried LMC? maybe Jeff's Bronco Graveyard stock them also.
Old Mar 3, 2011 | 10:40 PM
rla2005's Avatar
rla2005
Use a pick to pull one out. Take it to a good auto parts store or industrial supply house, either of those can set you up with a proper o-ring.
Old Mar 4, 2011 | 08:46 AM
F150xlt's Avatar
F150xlt
http://www.dormanproducts.com/docume...uyersGuide.pdf
If you're looking for the o'rings where the nylon hoses attach
to the fuel rail, scroll down to Dorman 800-013
May find them in the HELP section at the auto part store.
The fuel lines are 3/8 and 5/16.
Old Mar 4, 2011 | 10:10 AM
HD-runner's Avatar
HD-runner
Thanks! I have just ordered them and they will be here this afternoon. The lines are steel on the trucks but are not very long, they revert back to rubber with the nylon fittings and then use push lock clips. These o-rings look to be what I need, I will see soon. "Thanks again" Big Red XLT
MPD56
6.7L Power Stroke Diesel
1192
Oct 31, 2024 04:40 PM
54F350LNB
47
Aug 6, 2019 12:59 PM
bismic
Aug 10, 2015 10:35 AM
RANGER589
18
Jun 3, 2011 10:03 AM
smoky_diesel
34
Aug 14, 2008 04:45 PM
