The contents of the kit appear to be the same.. metal bushed, fittings, pins, etc.... Moog parts typicall cost more... I just rebuilt the front end of my Pontiac and went with all Moog branded parts.
i think the different options you will find are
1) normal sized brass bushings (require reaming)
2) normal sized nylon bushings (ez)
3) oversized brass bushings (require total rebore)
Get the Moog kit with the brass bushings. Ream them out to fit the kingpins ( or have a machine shop ream them for you ). They will last much longer than the Delrin bushings.
Have them measure the lengths of the kingpins in both sets. It seems to me that 1972 and 1973 years both used 2 different lengths of kingpins. I think that might account for the price difference. You might also call a local parts place and ask about this.
There's nothing wrong with the TRW's if it's just a closeout deal. Through 74 will use the same king pin set. I use the brass and have them fitted at a machine shop.
