ROMPING IDLE WHEN WARM
Old Mar 2, 2011 | 06:34 PM
PAVEMENTMAN's Avatar
PAVEMENTMAN
JUST WONDERING WHY MY IDLE ROMPS WHEN WARM AND RUNS SMOOTH WHEN COLD.
Old Mar 2, 2011 | 06:45 PM
Action4478's Avatar
Action4478
Are you using an ICP mod ?
Look at the ICP sensor ,see if its leaking oil
If an auto trans , does it do it in neutral ?
The romps are from the PCM being confused about something ...
Old Mar 2, 2011 | 06:48 PM
PAVEMENTMAN
NO MODS. JUST AN 6637 AIR CLEANER BUT IT DID IT BEFORE THAT. WHAT IS THE PCM AND WERE IS IT.
Old Mar 2, 2011 | 06:58 PM
BuckHammer's Avatar
BuckHammer
Can you post a video with sound of it doing it? It sounds eerily similar to what my truck likes to do.
Old Mar 2, 2011 | 07:00 PM
PAVEMENTMAN
I DONT HAVE ANY WAY OF DOING THAT. IT JUST DOES IT WHEN IT GETS WARM, IT SOUNDS LIKE IT HAS A BIG CAM IN IT OR SOMETHING.
Old Mar 2, 2011 | 07:07 PM
BuckHammer's Avatar
BuckHammer
Hey, could you please turn your capslock off?
Old Mar 2, 2011 | 07:41 PM
Action4478's Avatar
Action4478
Make sure you are not low on oil in the c case ...
Old Mar 2, 2011 | 07:47 PM
PAVEMENTMAN
All oil levels are full.
Old Mar 2, 2011 | 09:26 PM
fordpride's Avatar
fordpride
does it do it in Neutral
Old Mar 2, 2011 | 11:11 PM
oldbird1965's Avatar
oldbird1965
I'm probably wrong but didn't I read on here that's a IPR issue? Maybe its the other way around?
Old Mar 3, 2011 | 06:59 AM
PAVEMENTMAN
IT DOES IT ALL THE TIME ITS A 5 SPEED.
Old Mar 3, 2011 | 03:13 PM
makomark's Avatar
makomark
Like Action4478 said - PCM is 'confused'; most likely due to bad input data. Could be ICP sensor, IPR, even EOT sensor. A scantool would likely help in finding the 'bad guy'.
If no scan tool available, try running the engine with the ICP unplugged.
