charging issues
Old Mar 2, 2011 | 12:50 PM
frenchy107's Avatar
frenchy107
charging issues
89 f150 had a 4.9 inline and it wont start on a brand new battery unless hooked up to a battery charger or has 13.5 volts on it. also having overheating issues with the same truck, just replaced the head, both hoses and radiator, thermostat was jammed so i left it out
Old Mar 2, 2011 | 12:55 PM
planehunter's Avatar
planehunter
For the starting issue, make sure you connections and cables are in great condition. Did you also replace the water pump? You might have a lot of air trapped in the head.
Old Mar 2, 2011 | 01:35 PM
frenchy107's Avatar
frenchy107
water pump is new. forgot about that
Old Mar 2, 2011 | 07:07 PM
planehunter
Are you sure you used the right head gasket? Did you check to see if all passages continued through to the head?
