Head Gasket Replacement
Old Mar 2, 2011 | 10:23 AM
frdlvr35's Avatar
frdlvr35
I am getting ready to replace a blown head gasket on a 1979 F150 4X4 with a 400. The gasket is leaking oil down the driver side of the block after the engine runs for about 5 mins. This will be my first head gasket change and was wondering if anyone had any tips to make life easier. I am planning on doing it with the engine istalled because I have limited space to store engine removed. I have bought a complete gasket set from Fel Pro and am unsure what else I may need. Any comments and help would be appreciated.
Old Mar 2, 2011 | 10:46 AM
Sleepy445FE's Avatar
Sleepy445FE
A few tips..
Take the hood off. It will be MUCH easier to get to.
Have a friend ready to hand the head to so your arms dont fall off trying to lug that head out.
Make sure the deck surface is clear and clean and there are no chunks of old gasket left.
Make sure gaskets, head and intake, match bore and ports. dont leave anything to chance you know.
I would go ahead and do both head gaskets while you have it apart. You dont want to get it back together only to have the other side do the same thing.
Hope it helps some.
Old Mar 2, 2011 | 12:21 PM
frdlvr35's Avatar
frdlvr35
That is helpful advice. Thank you! How about changing the head bolts? I have seen some people reccommend it and others not.
Old Mar 2, 2011 | 12:37 PM
Steel Toy's Avatar
Steel Toy
Those are not torque to yield fasteners, don't see why you can't re-use them. Just pulled the 400 apart on my truck and I plan to clean them thoroughly and re-use them. Also be sure to run a tap into the threads on the block to clean them, but don't get crud into a cylinder. Put a bit of oil on the tap, it will help to hold the crud, I then run a shop vac over everything.
Old Mar 2, 2011 | 06:11 PM
Sleepy445FE
I always shop vac everything before reinstall as well. You can use the old bolts if you want. I just like upgrading when I can so I went with new arp bolts. It's not necessary just a peace of mind for me, so it's up to you which way you want to go. Agreed on threadchasing the bolt holes also.
Scout Pilot
Apr 11, 2012 03:10 PM
steveterryrudy
Mar 10, 2012 09:01 PM
kb1jid
Dec 11, 2011 07:05 PM
JoeVR5
1983 - 2012 Ranger & B-Series
Aug 9, 2011 09:07 AM
frdlvr35
Mar 3, 2011 07:51 AM
