Bronco II Ford Bronco II
Brake problem!!
Old Mar 13, 2003 | 06:59 PM
c-draper's Avatar
c-draper
Brake problem!!
What's going on. I have a problem I've just bought a 85 bronco II and I like everything about it. Wished it had a 302 in it instead of the 2.8. I changed carbs. on it it had all that electrical stuff on it so I got me a two barrell Holley and changed the jets so it wouldn't flood it. I think the rear brake cylinder is gone and the pedal hits the floor and when I go to pump the brake the motor dies. Is it because of the brake cylinder or is it a vaccum leak to the brakes. Any answers would be appreciated.
Craig Draper
85 bronco II and a 2000 Ford F-150
Old Mar 14, 2003 | 01:36 AM
bumpin_BII's Avatar
bumpin_BII
Brake problem!!
snds to me like a bad booster and master cylinder. the check valve is prolly shot. pull your back wheels off and check the cylinders. they go out at random sometimes.
Old Mar 16, 2003 | 12:34 PM
junkyarddog86's Avatar
junkyarddog86
Brake problem!!
also check you hoses to make sure that it is not leaking and connected to the right place.
Old Mar 18, 2003 | 12:16 PM
c-draper's Avatar
c-draper
Brake problem!!
I'm thinking it's the vaccum hose. I haven't had time to work on it much i'm going to school and working and plus girlfriend. It's just a little project i'm wanting to work on. Thanks for the advice.
Craig
