2000 Ex won't start.
Old Mar 1, 2011 | 04:36 AM
Bill4042's Avatar
Bill4042
Just about a week after having the 100k service done for the second time, the Ex ran a little rough (but not like when I had a little water under a COP), and then died, but started up and ran smoothly, and then roughly again, but let me limp home. It is not throwing a code, but now it will only turn over but not fire. I'm thinking fuel pump. Any other brilliant ideas?
In case my vehicles no longer show up in my signature (it's been awhile since I posted), it's a 2000 with the V10 and just over 200k.
Old Mar 1, 2011 | 11:13 AM
bp_1977's Avatar
bp_1977
Very well could be a fuel pump.
Mine went out at 116K.
However it could be just a clogged fuel filter too.
Might start there, reguardless you'll have to change it.
Old Mar 2, 2011 | 07:21 AM
tdappleman's Avatar
tdappleman
Can you hear the fuel pump run when you cycle the key? You have a couple of other things you can check as well before you replace any parts: Check the fuel pump shut off switch and the fuel pump fuse.
Old Mar 7, 2011 | 12:24 AM
Bill4042's Avatar
Bill4042
Changed the fuel filter friday. Saturday back to running like crap. MAF maybe?
Old Mar 7, 2011 | 12:32 AM
Bill4042's Avatar
Bill4042
Did I type just the fuel filter? Trying to listen to the wife while typing is harder than I thought. New fuel pump too.
Old Mar 7, 2011 | 07:32 AM
jh818's Avatar
jh818
I've heard you should change your fuel pump relay as well. I'm not sure which it is. I've looked in my manual and it didn't list it.
James527
Mar 9, 2015 10:37 PM
James527
Mar 9, 2015 09:35 PM
profounddd
Dec 28, 2009 12:23 AM
JDJHNTR
28
Nov 1, 2007 08:58 PM
Lanny Sutton
30
Jan 9, 2007 02:07 PM
