Oil Cooler replacement
Old Feb 28, 2011 | 08:39 PM
xXduneriderXx's Avatar
xXduneriderXx
So Ive been searching the threads for hours trying to find a pdf for how to replace the oil cooler mostly looking for the torque specs on the bolts i need to replace also since i drained the oil out of the area were the cooler sits if i need to fill it with new oil before putting it back together.
Thanks
Old Feb 28, 2011 | 08:48 PM
BobsF350's Avatar
BobsF350
planning on doing oil cooler egr delete glow plugs and cleaning the intake manifold this weekend.
so if someone can answer his ? and also give TQ for intake bolts
03 motor
Old Feb 28, 2011 | 08:57 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I haven't done this but have read that most fill the area with oil. It could take some cranking to fill that up before it will start.
As far as torque specs. All I can give you is this: (check the second one for standard torque values for different bolt sizes)
AND ALL OF THIS COMES FROM HERE: (MIGHT WANT TO KEEP IT HANDY)
http://www.backglass.org/duncan/ps60_manual/
Old Feb 28, 2011 | 09:00 PM
xXduneriderXx
For intake torque check the 6.0 tech folder and go to ford tech manual pdf and there is a intake removel pdf
Old Feb 28, 2011 | 09:04 PM
xXduneriderXx
Thumbs up
Thanks amdriven2liv
Old Feb 28, 2011 | 09:06 PM
amdriven2liv
Or he can get them in the link I shared.
Old Mar 1, 2011 | 04:38 AM
npccpartsman's Avatar
npccpartsman
You DEFINITELY want to fill the HPOP reservoir with very clean oil (2 or 3 quarts) before you put the oil cooler back on. It will save a LOT of wear and tear on your starter.
Chris611
6.7L Power Stroke Diesel
Nov 26, 2017 08:10 AM
akblackfoot
Apr 25, 2016 12:23 PM
billbot
Dec 27, 2015 10:51 PM
coldy12
Oct 1, 2015 11:55 AM
allons
Feb 2, 2014 11:27 AM
