Say it's not so
Old Mar 1, 2011 | 08:39 AM
  #31
ab123's Avatar
ab123
That is what I'll do. Thanks sooo much for the help, and if anyone knows somebody in my area that can help please let me know. Even a GOOD shop would be great.
Old Mar 1, 2011 | 09:21 AM
  #32
Brother Les's Avatar
Brother Les
Do you have your own garage to park your truck in? Do you have some basic tools and a multi-meter? You Do not need to take this to a Diesel shop.... yet or maybe never. time to learn about your truck and you will have fun doing it.
Let's test the Glow Plug Regulator and the Glow Plugs first. You can test the Glow Plugs without removing the Valve covers.
Old Mar 1, 2011 | 09:25 AM
  #33
izzybird's Avatar
izzybird
I hate to say this, but I'm leaning towards worn injectors. Do you get alot of white smoke while trying to start or at start and not plugged in? If so, that would point to a glow plug issue. The weather around here doesn't generally call for the need of GP's, though I hope it's an easy fix like this. If you have multiple injectors not firing on a cold motor it's probably not going to start. If the GP's check out, you can run a buzz test while motor is cold. If you have no way of doing the buzz test, yank the valve covers and watch oil discharge from each injector while cranking or running. The injectors not discharging oil are the culprits. After warm up, the injectors generally start firing and would explain your truck running fine after warm up. I'm not too far from you and can probably borrow a scantool (since I still don't have my own dangit)and help you out. But you really need to do the buzz test on a cold motor.
Old Mar 1, 2011 | 09:31 AM
  #34
JonathanN's Avatar
JonathanN
When my GP's were bad, mine ran like crap until it warmed up and it was a huge smoke show as well. I have 304K on my original sticks and my rotational velocity numbers are still VERY good. I think my worst is around 1.5%...
Old Mar 1, 2011 | 09:32 AM
  #35
Mitch1407's Avatar
Mitch1407
I had the same EXACT problem I believe. Does it chug like a freight train? or blow tons of white/gray smoke until warm while shaking and skipping?
I had an injector stuck wide open and overfueling it caused the cylinder to shut off til warm where it could handle it.
make sure you let us know what the culprit is
EDIT: I have a vid on youtube of what it did, search for my channel Mitch14077
  #36
ab123's Avatar
ab123
Yes, have a garage, tools, and multimeter. Have no scanning ability. This site is very helpful but it will take me a while to learn all the abbreviations, but I'm in no hurry I've got a "plug".
Old Mar 1, 2011 | 09:33 AM
  #37
Fishin76's Avatar
Fishin76
I haven't seen anyone mention the UVCH's, they could be getting loose and need replaced, the cooler temps could be causing them to not make as good of connections as they once did. using the block heater could be keeping the connectors warm and expanded, thus a good enough connection.
Old Mar 1, 2011 | 09:36 AM
  #38
ab123's Avatar
ab123
Yea, Mitch, sounds like mine, but could be more than one cylinder,but why would it not do it if plugged in?
Old Mar 1, 2011 | 09:40 AM
  #39
Mitch1407's Avatar
Mitch1407
Yes, it always starts and runs fine after beeing plugged in. that is why I wonder how it can be injectors.
I thought the same thing and Nissandoc helped me test mine and they were a little tired but not enough to cause the excessive smoking.
It will fool you into thinking its GPs but mine was smoking in 60* weather for about 10 mins and it didnt matter if it was 60* or 20* it would start the same if not plug in. My mechanic said that the reason it ran ok when plugged in was because it was warm enough to burn the excess fuel but when it was cold it wasnt.
Old Mar 1, 2011 | 09:47 AM
  #40
ab123's Avatar
ab123
Izzybird,you're making sence.How cold,do we need the motor? If it sits for 4hrs we can probably get a rough idle. Work brings me your way quite often.
Old Mar 1, 2011 | 09:48 AM
  #41
izzybird's Avatar
izzybird
Jump the Glow plug relay for about 30 seconds and try it. If it fires right off, you probably just need to get a new relay. There are a couple of good shops down around your area, I just can't pull them out of my head right now. Search function time.
Old Mar 1, 2011 | 09:55 AM
  #42
JonathanN's Avatar
JonathanN
Mine makes a little white haze, even when it's warm out. I don't doubt that my injectors are old and and might be worn, but they're not anywhere near bad enough to justify a new set. I think everybody else here has got the OP on the right track, though... start with the glow plug system.
Old Mar 1, 2011 | 10:01 AM
  #43
izzybird's Avatar
izzybird
If it was still 15 degrees around here, sitting 4 hrs would be fine. It would probably take all day for that big ol chunk of iron to cool down enough. I bet we can figure something out though. Check the Glow Plug system first, that's what we are going to hope is the problem. Of course we could throw in new glow plugs, glow plug relay, strengthen up the bottom end, hybrid injectors, tuning to run 'em, maybe a GQSSB turbo, big or medium oil, some giggle juice, high dollar transmission, and the list goes on. That should fix your issues and make you good pals with the local tire shop.
Old Mar 1, 2011 | 10:07 AM
  #44
ab123's Avatar
ab123
Everything is now sounding like injectors, except I don't have a lot of smoke.
  #45
izzybird's Avatar
izzybird
Oh, forgot.
Welcome to FTE!!
