Electric Lock Module
Old Feb 28, 2011 | 08:11 AM
97e150vanman's Avatar
97e150vanman
Hi I have a 2006 E-150 and the remote key-less entry system quit working. It is not the batterys or key fobs. The locks work with in the van but not the key fobs. When I try to reprogram the system I go through the all the steps ok, the system indicates ready to program but does not accept the signal from the remotes. The remotes are ok they have been tested. I think the keyless module or antenna is faulty. Where is the module located?????
Old Mar 1, 2011 | 08:42 AM
Franklin2's Avatar
Franklin2
The latest autozone has is 2005 component location views. If this link doesn't work, go to autozone's site and register, then plug in your vehicle, and click on "repair guides". Then click on "wiring diagrams" and then "component location views".
| Repair Guides | Component Location Views (2005) | Component Location Views (2005) 1 | AutoZone.com
