My First FORD
Old Feb 27, 2011 | 11:04 PM
whitewalls's Avatar
whitewalls
Thumbs up My First FORD
Hi fellow members!
I was looking at joining a ford enthusiast's forum, for wisdom, guidance & knowledge. I luckily stumbled upon this site. Reading some post's, you lot seem like a great bunch.
I will soon own my "first" Classic truck! (I'm sure there will be more). As well, my first FORD. So I was hoping to find some guidance from anyone willing to help a newbie out!
Looking at a beautiful turn key 1966 F100 long box. 4 on the floor. I believe it has a 352, but I could definitely be mistaken. & the origin of the truck is Texas. I will be going up again to see it in closer detail and take some photo's as well as drive it (weather pending). Just curious what to look for specifically or ask the owner when I see it next/before I buy?
Any advice you lot can share before getting way too excited?
I apologize for my lack of knowledge and terminology.
Here to learn!
-ww
Old Feb 27, 2011 | 11:42 PM
jhooch's Avatar
jhooch
This truck would have a 352 if it is an original V8 truck and the motor has not been changed. 360's, 390's, etc. look the same externally. Look for rust in the usual places, drip rails above doors, cab corners, floorbaoards, front of bed floor, core support, etc. Not that any of that can't be fixed, but the more rust the more work and $. Post some pics and a warranty plate and we'll try to help best we can.
Jeff
Old Feb 27, 2011 | 11:56 PM
nice1960f250's Avatar
nice1960f250
post some pics please
Old Feb 28, 2011 | 07:19 AM
whitewalls's Avatar
whitewalls
Great!
Yes, as soon as I get photos I will post them.
Thank you-
Old Feb 28, 2011 | 08:00 AM
FL299's Avatar
FL299
It sounds like you have found a very good truck with a great combination in my opinion. I also feel that these trucks are some of the nicest trucks FORD has built. I hope you have great success with your truck and I am sure you will !
Old Feb 28, 2011 | 08:31 AM
CropDusterMan's Avatar
CropDusterMan
Hey Whitewalls,
Welcome to the site. As you mentioned you were unfamiliar with terminology, I'll just define some of the terms
mentioned above...These trucks are known for rust in the following areas:
"Core Support"-this is what the Radiator attaches too...if you open the hood and look down behind the headlights,
if you see rust holes, that's not good, it's very common.
"Cab Mounts"-Look under the front fender towards the cab, you'll see a triangular
shaped part attached to the cab that bolts to the frame...these commonly rusted out.
"Floor Panels"-pretty obvious, just crawl under and look at the areas of the floor for rust, as long as it's around
where your feet would sit, it's not a big deal, but if it's along the area where the doors go, this is a trickier repair.
"Drip Rails"- or rain gutters are the areas above the windshield...these had a caulking type of material originally
that flaked away leaving the seams vulnerable to moisture and then rust and if it's a lot. it'll usually be severe.
Hood-Check the hood at the front from the inside...these areas are very commonly rusted out and usually show
from the outside. The hood hinges may also be worn out, you'll know 'cause the hood won't open or close smoothly
or sit flush.
One other area to look is underneath the truck, below the cab, there is a cross-member
that collects a lot of dirt internally and can rust badly.
All of the above mentioned can be repaired, depending on your mechanical prowess or funds available for parts
and so forth...but if a lot of these areas look bad, you may wanna keep lookin'!
Hope this helps you out....Good luck!
Jason
Old Feb 28, 2011 | 11:49 PM
whitewalls's Avatar
whitewalls
Nice to hear from you Jhooch, Nice, FL299 & CropDusterMan (Jason).
I thank you for taking the time to reply to my message. You have & will provide a lot of help and guidance for a younger guy like myself just getting into it.
Thanks Jason for going in depth with your reply.
Appreciated-
-Michael
Will keep you posted on how my next visit goes and hope to get photos uploaded.
If anyone else has anything else that has been unmentioned. Good or bad, I would like to hear it. Thanks*
