Front Differential
Old Mar 13, 2003 | 03:04 PM
blacksunshine's Avatar
blacksunshine
Front Differential
i noticed on the front diff. that there is no solid axles can i just change the center section with one from a donnor truck and is there one that comes with a 4.10 gear stock ,i have a 150 does the 250 interchange if so does it have the bigger gears i need?
also if i just put 4.10 gears in mine were can i find the gear and the carrier to get this job done?
Upper Case edited out by Admin.
Old Mar 13, 2003 | 09:35 PM
Boss_358's Avatar
Boss_358
Front Differential
First off, if you could please not post all in caps that would be great.
On The Internet it is considered shouting, plus, it is also difficult for some of User's to read.
Thank you.
Now for your question, I am going to answer it as best as I can with the amount of information you have given. I am assuming that you are referring to the Twin Traction Beam axle in the front of your 93 F-150. Even though it is independent the center carrier is still a reverse cut Dana 44. Any Dana 44 reverse cut gear set should work and I am assuming that someone makes a 4.10 set. As far as the F-250 Axle goes, this is a Dana 50. It is a heavier duty version of the dana 44. The whole housing will not swap because the F-250 version of the TTB sits on leaf springs rather than the coils that the F-150 version sits on. But all of the internal components of the Dana 50 should swap into a 44 housing, this is if you want a 3/4 ton 8 lug set up in the front.
Old Mar 13, 2003 | 11:20 PM
blacksunshine
Front Differential
first off! don't tell me how to type, secondly maybe i just wanted everyone to hear me! and last but not least you just lost a member mr. boss man
This one has been edited too.
Old Mar 13, 2003 | 11:49 PM
Boss_358's Avatar
Boss_358
Front Differential
Your welcome. Always happy to give a little technical info now and then.
Sometimes the best way to get HEARD is to use correct spelling and punctuation. Then maybe someone can understand what you are trying to say. Have a nice day.
Old Mar 14, 2003 | 09:39 AM
ford_nut's Avatar
ford_nut
Front Differential
This makes me laugh! We have a great message board here and who needs an idiot like this?? Just goes to illustrate some of the juvenile mentality!
regards
Ben
Old Mar 14, 2003 | 11:40 AM
Boss_358's Avatar
Boss_358
Front Differential
The funniest part is that I did not even edit his post. It clearly says that the post was edited by Admin., not the Moderator.
