"69" 429
Old Feb 27, 2011 | 12:56 PM
Roadglide81's Avatar
Roadglide81
"69" 429
I have a line on a 1969 429. I emailed the seller trying to get the engine code and got this response.
"Ya np separating the two, C9VE-B and the head C9VE-A. Been having trouble getting a straight answer on the motor type, CJ or standard, I am going to pull intake and pan to get number off the crank and there should be a CJ stamp in valley if its a CJ I think. I was going to do this today.
Engine ran fine when I pulled it, only issue was off idle hesitation, which would be a little carb adjustment and timing. Tanny shifted good also."
He bought it in a 63 F100 and was told it was out of a 69 Lincoln but that's 2nd hand info.
I'm looking to put it in my 78 F150 Ranger XLT short box and would appriciate some help on value and specs. I'm running a 400M at this time and would like to add more power.
Thanks in advance,
Roadglide81
Old Feb 27, 2011 | 02:24 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
429 cobra jet's were 70 & 71 with a D0OE-R engineering # cast into them. Part # 6090.
Ask him if it has a spread bore intake manifold.
Old Mar 1, 2011 | 08:18 AM
429CJ-3X2's Avatar
429CJ-3X2
Definitely not a CJ with those part #s. If it's from a '69 Lincoln, would it be a 429 or 460? The '69 T-Birds had 429's, not sure about the Lincolns.
Off topic question - is your '78 F150 short box 2WD or 4WD? The reason I ask is I had a '78 F100 Ranger XLT short box 2WD, 400, C6, heavy springs, most of the options available. The only reason for it being an F100 instead of a 150 that I could come up with was it was 2WD. Had it been 4WD or a long box, it would have been an F150 by the info I found.
Old Mar 7, 2011 | 04:45 PM
Bear 45/70's Avatar
Bear 45/70
The 1969 429 was not available in the Lincoln, only the 460. So there are lies flying around. The 1969 429 was available in two versions 2 and 4 barrel. The 2V had a 10.5 to 1 compression at 320 hp @4400 and 460 ft.lbs @ 2200. The 4V was 11 to 1 with 360 hp @ 4600 and 480 ft/lbs @ 2800.
bismic
Mar 9, 2022 09:20 AM
NMFirstF2504X4
Jul 14, 2015 07:40 AM
230thdratsab
Sep 15, 2013 07:05 PM
glruff
Maryland Chapter
Aug 17, 2007 05:52 PM
johnny8
13
Nov 26, 2005 09:21 PM
