Sponsored by: Real Truck
2006 SD fuel gage testing
Old Feb 27, 2011 | 09:01 AM
tomswell's Avatar
tomswell
Question 2006 SD fuel gage testing
I have a California F450 SD with healthy fuel sender reading 15 > 150 OHM
I need to explore cluster connector and gage.
Gage always reads empty, although when ignition is first turned on gage blipps to the middle of "E" and falls back down.
I found 2005 Workshop manual ... is 2006 similar ?
Workshop Manual 2005 / fuel gage
Is the cluster connector 220b accessed under dash
I've looked under hood & dash and disconnected and inspected every connector!, none look like workshop manual & have BK/OG & YE/WH wires ...
where is cluster connector?
I'm about to order GoLink cable ... software looks great. GL1-OBD Reader-GoLink for iPhone | GoPoint Technology
workshop manual check#B4 ... says clear DTCs if voltage is present.
how to clear DTCs without OBDC tool ?
I've disconnected batteries for hour or so without change.
The strangest thing is the gage worked for a couple of minutes when I moved truck in order to inspect all wires
Then when ignition was turned on again ... back to "E" only blip.
It maby fuel pump module problem.
So I kinda doubt the gage is toast.
Last edited by tomswell; Feb 28, 2011 at 01:43 PM. Reason: found workshop manual / can't find connector.
WQ59B
1947 and Older Ford Trucks
15
Mar 23, 2016 06:29 AM
CheckEngine
1983 - 2012 Ranger & B-Series
Oct 1, 2015 07:04 PM
93nighthawk
Aerostar
39
Sep 23, 2015 08:55 PM
cheezit
Jun 24, 2010 07:16 PM
steve83
Computer Chips & Tuners
May 19, 2003 05:50 PM
