I've read some about the modified B code. What's the story with that? Is there an advantage?
With the V codes up front, putting in modified B's in back eliminates the need for the 3.5" tapered blocks to keep the same rake/stance. You just reuse the Excursion OEM blocks.
Since you carry a load often, I'd go with W codes up front, Modified B codes out back (keep the stock Excursion blocks) along with the RAS.
Stewart
Stewart,
Thanks for the reply's.
You have alot of good info on our trucks.
I read one of your posts were you indicated your V codes were starting to sag after 100,000 or so miles on them.
You fealt the W codes (f-450,f-550 non snow plow )would be the way to go the 2nd time around. Once they settled they would be at level of V codes and probably wouldn't have to be replaced again due to sagging.
You fealt the ride wouldn't be as hard as x-codes (snow plow).
Did you do that swap yet.
Money is tight and I thought about used W codes ($200) after settling(sag) might be at level with new V codes?
Stock Rear springs, with 350 tappered blocks.(will that level me out)?
RAS later
Or used V codes with saging (wear) might put me level with rear with out tappered blocks and only RAS to level it out?
Any in put on above would be appricated.(#############)
I wouldn't use the term sag, but rather settled over time.
To me, sagging connotates the springs are no longer useful. Mine still are, they just aren't as high (slightly lower now) as when first put on, but they still work quite well.
I want to go with W's not because my V's are sagging, but because they'll give more lift over the V's.
Correct, based on other users who have done the W codes.
No. That won't happen for a few more years at the earliest. My setup is still working very well, I just would like a hair more lift and the W's would provide that.
RAS later
Don't keep the stock rear springs. While the front springs help with the Excursion steering wander, it's the weak rear springs on the Ex that is the main culprit allowing rear-end steer causing the wander.
So I'm getting everything ready to do my V and P swap next weekend and I measured my wheel opening height today to try and figure out what size rear block I need. I measured 38 3/8 in the front and 38 1/2 in the rear. I was expecting to get the 1 1/2 inch lift in the front but the guys that gained that much lift say they started with 37 1/2". Does that mean that I will only get about 3/4" lift in the front? How bout the rear. Most guys say they started with around 40 and ended up with 40 1/2 with the B swap. I am doing P's which I think is the same as a B because the rate is the same but will I end up seeing an 1 1/2" to 2" in the back? All I'm trying to do is figure out what blocks and U-bolts I will need. Any thoughts?
For reference-
Past 03 X V10 4X4- Did V codes and gained 2" front. Added F350 rear tapered block and ubolts to bring the rear up 2".
Current 01 7.3 4X4- Did X codes and F350 rear tapered block and ubolts.. Gained 2" all around. The front springs have settled a bit more on the diesel than the V10 obviously. Thats why i went with X codes on the diesel. Ride is not bad at all. As far as shocks, I used stock length in both cases. The X codes pushed the limit on the diesel as they were not far from being topped out when the springs were new. Not that they have settled, I am not worried about it.
Remember those measurement are subjective to the different tire sizes/ wear that everyone uses.
The u bolts should be replaced with new, so if you have to cut them off because of rust I wouldn't worry too much about it. There are stock #'s somewhere for the front u bolts to use, the rear ones will be a little harder to match so you might want to find someone in the area that makes them and get some made after the swap and measurements are taken.
I modified F codes by adding last two leafs from Excursion spring pack. Throw out the Excursion overload with bumper. This gives a the proper rake and height needed for a good ride, along with V codes up front. See picture in sig.
Ditto the X codes. I put them on my 2000 V10 and didn't notice the ride worsening. They sure handled my plow better. That was b4 I lifted it.
Have any of you guys used front shackles and if so which ones? I have 6"BDS lift and need a little more up front to eliminate rubbing. BDS claims on the Ex you have to do both front hangers...
I did the V/modified F swap a while back. It's the best thing I have done so far to the truck. I do wish I had gone bigger in the front tho. From the ground to the top of the wheel well is 43.5" in the back and 39" in the front. Getting ready to put 35" tires on it and another inch or two up front would be nice. Trying to decide if I should swap again to X codes, add blocks or what.Any suggestions? Anyone have part numbers for the X codes?
