I have a 1-1/2 ton that I have tentatively identified as a 1940 based on the headlight configuration (signal lights in the base of the headlight mount). I cannot find a serial number anywhere on the vehicle but the registration slip shows the number as HTB61512. Can anyone help me out here?
I am also looking for a source for overhaul manuals for this truck as I have started a ground-up restoration.
As for the VIN location, I may be out of luck finding it on the frame rail. This truck is a fire truck and the frame rails were cut off right in front of the front spring hangers to accomodate a pump.
