Are new up pipes really nec?
#32
I did forget to mention that when I did my repairs on my upipes, I also replaced the bolts up top with new ones. I used inset allen wrench head bolts instead of the orignal 5 point head bolts. It sure makes it easier to take out, and put back in as well.. Just some info for ya'll to think about when do'n these repairs.
#33
Replacing the bolts is a good idea. Little 10mm head bolts for an exhaust (corrosive) application isn't good. I am into it for more than I thought, first bolt at the top of upppipe broke of course, so turbo is comimg off!
For the record, stock uppipes at my Ford dealer were 95.00, +28.00 for little donuts. I was lucky and got a "good buddy" 20% off, but all things considered going stock can be a little pricey also. There is a pretty bad groove worn in the drivers side pipe, so replacement is nec. The OEM pipes are pretty overpriced for what they are.
I have always questioned why stainless fastners aren't used for exhaust parts!!
More fun later today, not done yet.
Tom.
Tom.
#34
#35
You drill and tap the exhaust manifold, its easy - the up-pipes aren't in the way at all. I really obsessed about this task and went overboard to remove the shavings - now I realize this was not really necessary. Yes, we want to get the metal out, but a vacuum and magnetized bent nail are sufficient. Anything left in there is rapidly blown out at LOW VELOCITY as soon as engine cranks up....
#37
Tom.
Tom.
#38
I have cursed ss hardware for one simple thing, when the threads gaud you can hang it up. So words of advice, no matter how messy neverseize is use it or you'll regret it. Also ss is softer and can't take the torque like carbor. So with ss the only advantage I have found is you can normally break the bolts off easier than trying to back them off. If you do use ss on your exaust I would recommend some high temp neverseize and I'm not sure if it would even hold up but it would be better than nothing!
#39
I had a lug bolt break off. Oh, what a joy. It would have been easier if it was a stud but no, it had to be a bolt. All my bolts get a good dose of it today. Any time the rotors or wheels come off, the mating surfaces that tend to get stuck get whacked with the goop. I pounded and pounded but it wouldn't come off. I had to take it to Sears who put it on a hoist and levered it with a huge crow bar. I drove around and around, braking the vehicle with the bolts loose but no luck.
#40
#41
#42
#43
I guess I might as well add last thoughts. After having to replace the exhaust inlet manifold, up pipes, o-rings for turbo stuff, and I added cost of new bolts, real close to 350.00 and some change. Without good buddy discount, over 400 easy.
This morning I looked at Guzzle's site, 438.00 for above, and better stuff to boot. Boy, trying to save money just doesn't work sometimes!!
Either way though, not a fun job. At least it is done, for a while.
#44
Either way, you can't go wrong with those guys
#45
Usually when I buy the cheaper stuff, it breaks faster and I have to do it again. IF it works, I outgrow it so fast that I have to buy the better one now. Would have been cheaper to buy the good one the first time and grow into it as opposed to buying the cheap one and grow out of it much too soon.
