1978 - 1996 Big Bronco
TSB lug nuts
Old Mar 12, 2003 | 09:44 PM
Dutch123's Avatar
Dutch123
TSB lug nuts
I recall a post regarding a TSB for using a torch wrench on lug nuts. I need help finding the TSB or post.
Thanks
Dutch
Old Mar 13, 2003 | 07:59 AM
AlM's Avatar
AlM
TSB lug nuts
yo Dutch,
Here it is:
"MARCH 18, 1998
FORD:
1972-97 THUNDERBIRD
1976-86 LTD
1976-97 MUSTANG
1981-97 CROWN VICTORIA
1982-88 EXP
1982-98 ESCORT
1984-94 TEMPO
1986-97 TAURUS
1988-93 FESTIVA
1989-97 PROBE
1994-97 ASPIRE
1995-98 CONTOUR
LINCOLN-MERCURY:
1979-83 MONARCH, ZEPHYR
1979-97 COUGAR
1980-83 MARK VI
1980-98 CONTINENTAL, TOWN CAR
1981-86 LYNX
1983-86 MARQUIS
1984-92 MARK VII
1984-94 TOPAZ
1986-97 SABLE
1987-89 TRACER
1987-97 GRAND MARQUIS
1991-94 CAPRI
1991-97 TRACER
1993-98 MARK VIII
1995-98 MYSTIQUE
LIGHT TRUCK:
1979-96 BRONCO
1979-97 ECONOLINE, F-150-350 SERIES
1984-90 BRONCO II
1984-97 RANGER
1986-97 AEROSTAR
1988-97 F SUPER DUTY
1991-97 EXPLORER
1993-97 VILLAGER
1995-98 WINDSTAR
1997 EXPEDITION
1998 NAVIGATOR
ISSUE:
The use of air impact tools to tighten wheel lug nuts can lead to overtightened and/or unevenly tightened wheel lug nuts. Air impact tools typically used for wheel lug nut removal and installation can generate up to 475 N-m (350 lb-ft) of torque. Overtightened and/or unevenly torqued wheel lug nuts may cause:
- Brake vibration
- Distortion of the wheel hub
- Distortion of the brake rotor
- Brake rotor runout
- Damage to the wheel
- Damage to the wheel nuts and studs
ACTION:
All wheel lug nuts should only be tightened to specification using a torque wrench or by using the Rotunda ACCUTORQ 164-R0314 or equivalent on a 1/2" drive air impact tool. The "ACCUTORQ" lug nut sockets limit the torque of the air impact tool, preventing overtightening or uneven tightening of the wheel lug nuts. The torque limiting devices (regulators) on air impact tools will not reduce the output torque enough to prevent overtightening of the wheel lug nuts.
NOTE:
REFER TO THE APPROPRIATE SERVICE MANUAL OR THE CHART IN «FIGURE 1» FOR THE CORRECT WHEEL LUG NUT TORQUE SPECIFICATION. THE CHART IN «FIGURE 1» ALSO PROVIDES THE CORRECT "ACCUTORQ" LUG NUT SOCKET TO USE.
Figure 1 - Article 98-5A-4
The "ACCUTORQ" socket is intended for lug nut installation, not removal. When using the "ACCUTORQ" socket, the output torque of the air impact tool must be set to 217-339 N-m (160-250 lb-ft), usually this will be the lowest setting on the air impact tool.
The "ACCUTORQ" lug nut sockets are available through Rotunda Equipment. The four-piece set (164-R0314) fits most Ford Motor Company cars and light trucks. The tool set consists of four (4) lug nut sockets and a storage case. The set can be ordered by calling Rotunda Equipment at 1-800-ROT-UNDA (768-8632).
CAUTION:
AIR IMPACT TOOLS SHOULD NOT BE USED TO TIGHTEN WHEEL LUG NUTS UNLESS THE "ACCUTORQ" LUG NUT SOCKET OF THE CORRECT SPECIFICATION IS USED.
NOTE:
DO NOT USE AIR IMPACT TOOLS ON LOCKING WHEEL LUG NUTS. THEY ARE TO BE HAND-TORQUED ONLY.
OTHER APPLICABLE ARTICLES: NONE
SUPERSEDES: 97-17-6
WARRANTY STATUS: INFORMATION ONLY
OASIS CODES: 301000, 303000, 306000"
http://www.diesel-central.com/Tech/f...cs/98-5A-4.doc
berry1234
19
Apr 7, 2008 03:09 PM
Dutch123
May 31, 2005 01:24 AM
Dutch123
13
Dec 1, 2004 08:14 AM
Dutch123
May 23, 2003 09:34 PM
Dutch123
Computer Chips & Tuners
Feb 10, 2003 07:48 PM
