88 f250 needs help!
Old Feb 22, 2011 | 05:26 PM
bivens1974's Avatar
bivens1974
Unhappy 88 f250 needs help!
hi i hav a 88 f250 351efi c6 4wd it runs good but its got what i call a stumble a idle not a miss you might help me on that also but its dyin now i can start it & drive to work with no problem but i might make it home or not i thank sumthangs breakin down i replaced coil moduel on dist. both made in USA & rebuilt computer im thankin a new dist. or crank sensor i need help please let me know what you think thanks
Old Feb 23, 2011 | 07:17 AM
Lazy K's Avatar
Lazy K
Ford Fuel Injection » How To Run a Self-Test Here is a link on how to check for any trouble codes, may help in finding the problem.
Maybe also fit a new fuel filter and check for a restricted exhaust (plugged cat).
Old Feb 23, 2011 | 06:06 PM
bivens1974's Avatar
bivens1974
it has pressure at the fuel rail but might not be enough last time it quit it started back & it sounded like it was runnin on 3 cylinders had to pull it home next day started up & ran good it still has all the cats too i will check it out thanx
