Hard starting, rough acceleration
Old Feb 22, 2011 | 01:28 PM
Inlinetorque's Avatar
Inlinetorque
I rebuilt my carter carb this weekend and have reinstalled it back into the truck. It ran better when I got it to run, the problem is it now starts very hard, if at all, and dies if I don't feather the throttle for awhile. I was wondering if anyone could possibly know what the fix is to this? Is the air/fuel mixture screw set wrong, or could it be the float? When it does run, it will lag at acceleration for a second, then the RPM's will climb up fast. Any help on this issue is much appreciated.
Old Feb 22, 2011 | 05:04 PM
Inlinetorque
Took the top half of the carb off, adjusted the float to specs, it starts much easier didn't have to throttle it the second time, still has a slight hesitation when I start pressing on the pedal, however its only if I depress it slowly, if I floor it fast it won't hesitate.
