Found my leak!
Old Feb 21, 2011 | 06:47 PM
bad12jr's Avatar
bad12jr
Found my leak!
Well guys I found my leak. The front cover is cracked where the oil cooler bolts on. Well I don't have time or place to pull the motor so I have attempted to seal it with fasweld. Well the leak is much less then it was but is still leaking.
Here is my question. It is just a hair line crack the leaks under pressure.
What do you all think about bars leak or alumaseal. Will it stop up the heater core. I think it will work. But want your all's opinion.
Old Feb 21, 2011 | 06:51 PM
Action4478's Avatar
Action4478
You may be able to relieve the crack with a grinder or a dremell tool & use JB weld ...
Old Feb 21, 2011 | 06:59 PM
bad12jr's Avatar
bad12jr
I cleaned it with a dremel. It wont stick to the aluminum on the bend. I dont wanna take material out. Not sure how thick it is.
Old Feb 21, 2011 | 07:03 PM
Action4478's Avatar
Action4478
V it out , what do you have to lose ?
Worst case you have to replace the cover , which you already know ..
Old Feb 21, 2011 | 07:20 PM
bad12jr's Avatar
bad12jr
True. I might just have to try that. The only problem in getting the fas weld off.
