im trying to install a new cd player in my truck. the PO did some serious stupid stuff. what are the wires the PO cut off the harness and what will they goto on my new cd player???
ide like to use the wires that were factory if i can. plus run my own speaker wires (doing this now). just need to know what that harness is and what the wires are....
Constant 12V+ Light Green
Switched 12V+ Yellow/Black
Illumination Blue/Brown
Front Speakers 5 1/4" Doors
Left Front (+) Green
Left Front (-) Black/White
Right Front (+) White/Red
Right Front (-) Black/White
You'll need to add a ground wire....the factory setup grounds through the chasis, but this should get you going...
thank you all for the help with figuring out the wires! got it all hooked up and working. now all i need is the dash install kit... got one but its not right. im looking online right now and havent found what i need yet. anyone know the kit i need?
I know this is an old post, but does anyone know if there was an install bracket kit found? I installed a cd player in my 86' and I have no idea how to get it to mount up. It would be nice if there is an install bracket for cd players. Thanks for any help.
Autozone sells the cheap plastic ones that break when you hit a bump. I got lucky and found one in a junk yard that was made of metal, which I imagine is a factory DIN mount.
What is DIN? I am unfamiliar with that term. Are the autozone brackets not worth getting?
What I did was take the original radio out of the factory casing (one piece radio & case) but I used the bottom I_I (< pic) style and mounted my new radio in that, then just went back with the front cover and new trim plate.
Bit of sweat but worth it.
Great wiring diagram wonder where I've seen it before
When I bought the truck in February it didn't have the stock radio, or any radio for that matter. Guess I will make up something.
