Front end service kit
Old Feb 21, 2011 | 12:04 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
Anyone make one? I'm looking for a kit to re-build the front suspension, replace all the bushings, bearings, etc. Basically replace any and all of the parts that wear out. At some point in the next few years I'd like to have a camper on this truck again, so I figure I had better get the suspension up to the task. (the engine and transmission are another story) A kit for the rear axle would be nice too, but I think I could piece one together. The truck is my 2 wheel drive 1973 Ford F250 Camper Special with 7500 lb GVWR and DANA 60 rear axle, dual piston caliper brakes on the front, manual steering with power brakes.
Sam
Old Feb 21, 2011 | 04:05 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Have you checked with our FTE Ford truck sponsors and the top of the page? I am sure someone has a kit.... or can get you all the parts.
I have a stack of free catalogs from them all to eye ball in the shop when I need a break.
BOTP Blue Oval Truck Parts
NPD National Parts Depot
BG Bronco Graveyard
DC Dennis carpenter
LMC
Old Feb 23, 2011 | 02:57 PM
Rusty_Old_F250
Alright, thanks. I've got a couple of the catalogs, great stuff. I look through them often! As for the kit, I might just have to piece it together, I was hoping to avoid it, a kit would probably be cheaper (and easier!)
One quick question: does a 2wd F-250 (same truck as above) use kingpins? If so, anyone know what size?
Sam
Old Feb 23, 2011 | 03:11 PM
77&79F250's Avatar
77&79F250
Ha 2wd folks answer up.......as a 4x4 guy I would say no, but could be wrong as a 350 in a t-bucket, that's just WRONG!
Old Feb 23, 2011 | 06:27 PM
Pop's76's Avatar
Pop's76
my 76 f100 2wd has king pins. I am not sure of the size but when you give them your year model they should have the appropriate ones. I have looke at a set for mine but my problem was trying to decide between the nylon or brass bushings.
Rusty_Old_F250
1947 and Older Ford Trucks
Mar 18, 2014 07:09 AM
Rusty_Old_F250
Mar 4, 2014 02:55 AM
Robert6401
Mar 7, 2012 11:24 AM
Rusty_Old_F250
Dec 24, 2011 01:54 PM
