4x2 wheel bearings
Old Feb 20, 2011 | 10:24 PM
jakojohnston's Avatar
jakojohnston
8th Gear
4x2 wheel bearings
can anyone give me advise on changing the wheel bearings on a 93 f150 2wd?? never done bearings, fairly mechanically inclined, just never done bearings. also, does anyone know what it takes to bring the idle down to around 550 to 600 on the throttle body injected 5.0? throttle body is adjust as far out as it can go and still idling around 800. freshly rebuilt engine and sounds awsome, might sound lil better at a lil lower idle with lil bit of a lope idle.
Old Feb 21, 2011 | 09:06 AM
rla2005's Avatar
rla2005
The idle RPM is controlled by the engine computer (PCM). Adjusting that idle stop screw is not recommended. The factory idle RPM is around 600 RPM in drive IIRC. If your idle RPM is above that with a warm engine in drive then you may have a vacuum leak or perhaps the TPS is faulty.
