transfer case and trany question
Old Feb 20, 2011 | 02:25 PM
sckootter16's Avatar
sckootter16
I have a 1981 f150 with a 300 engine the trans is a four speed with ganny. Not sure what transfer case I have. I am wanting to change my trans and transfer lube. What lube does the trans and transfer take? Anyone know?
Old Feb 20, 2011 | 03:43 PM
guindian28's Avatar
guindian28
your transfer case should have a tag on it, on the door sticker there will be a trans code to let you know what transmission you have if it's still original
Old Feb 20, 2011 | 06:26 PM
fordman75's Avatar
fordman75
Unless it's been changed your transfercase should be a NP208.
It's been a while since I had a NP208 but I think it took ATF. But you'll want to double check that.
Old Feb 20, 2011 | 08:49 PM
sckootter16
where could I go or who could I call to find out what lube to use in my transfer and trany?
Old Feb 20, 2011 | 09:02 PM
fordman75's Avatar
fordman75
Google is your friend!
I did a quick search at came up with Dextron ATF.
Old Feb 20, 2011 | 09:22 PM
6fifty_f1fifty's Avatar
6fifty_f1fifty
Yep local offroad place told me ATF or 10-30 synthetic for the np208
Manual tranny should be heavy gear oil 75-90 wt
Old Feb 21, 2011 | 12:43 AM
sckootter16
ok so 75-90 wt gear oil in the trany and atf for the trans case.
